Hello all, Can anybody suggest how to hook up cables from Replicape to this
Hello all,
Can anybody suggest how to hook up cables from Replicape to this heatbed?
Depends on the power supply voltage you are using. I use this bed. For 12v you solder +12v to pad 1 and run replicape hotbed- to pad 2 and 3 (you can solder a short wire between 2 and 3 or run two ground wires back to the replicape hotbed terminal.
