Having the same problem after changing the tube for a brand new one by Shanghai TongLi. So added the Ampere Meter and found the output to be 1 mAh, Guys do you think it is the front control panel or the PSU?
Seems that the buttons sometimes behave different from what you expect such as when you want to increase, it decreases and so on. Or should I get them to ship the PSU to Singapore. Too exhausted to fly up again as next week I will be in LA.
@StephaneBUISSON That was what I am thinking, so a 1k ohm pot will work to do some testing. Might as well try it. At least shipping that is easier than pusing 2 Laser Tubes from Shenzhen to Singapore.
different psu around, but very similar, sometime they connect on different ground pin on psu, on mine I have only the 5v from middle connector (read K40+Smoothie=SmoothK40)
Okay, results are in, it is the PSU, after spending SGD$4.20 (SGD$1.20 for the 3 pin, SGD$1.00 for the 2 pin and SGD$1.00 for the pot) to confirm. But I think it is good to have the analog backup to test.
Just for the record
G => Pin 1 1K ohm Pot
IN => Pin 2 1K ohm Pot
5V => Pin 3 1K ohm Pot
