Having some trouble with exporting from autocad 2016 to STL.
does it but nothing in the file
have you tried turning it off and back on again? :wink:
The command is stlout and then select object
must have a solid object there, if your object isn’t closed and filled the stl file have nothing inside
Thank you we figured it out. The model has to be in positive space.
