Has anyone tried storing CRGB values in EEPROM? If I use the CRGB struct then I get 0,0,0 after a read, but if I use a uint32_t in the structs instead then it returns the value correctly.
If it matters I am using eeprom_read_block to pull the struct out of the EEPROM. The example is a dummy struct, but my real one has multiple fields of various primitive types that all load fine. It is only the CRGB that fails to load, so I am fairly confident it is not the way I am retreiving it.
Strange. If I edit the SRAM copy of my struct then store it using eeprom_write_block then it gets loaded correctly through resets. It appears that it is just the initial value stored in the .eep is incorrect. I have not tried any other structs/classes yet as this primarily an led project
Did a little bit of inspection. Looking at the generated .eep file it appears each color is 0x000000 which is then uploaded to the EEPROM. So for some reason gcc/g++ is not generating the struct correctly. If it helps this is the file format the .eep uses - https://en.wikipedia.org/wiki/Intel_HEX.
EDIT: I manually edited the bytes in the eep file and the colors are loaded and shown correctly. So it is definitely just the files generation that is screwy.
That’s what it appears like. Even if I do something like 0xFF0000 it fails if the type in the struct is CRGB. As mentioned before changing the type to uint32_t fixes it. I would try to make it a const but I can’t change the struct definition as I want create an in ram copy at the start of the program than can then be edited and rewritten to the eeprom.
Yeah - because CRGB has a constructor it will be initialized at run, not compile time.
However, since it’s structure is simple - you can set it up as just a 3 byte array in your generation - and the. The loading code can just treat it as a CRGB
@Daniel_Garcia sadly that didn’t seem to work when I tested it last night. Maybe making it a separate variable is the key (I was doing nested brackets/initialization)
Thanks for the suggestions guys. Something like Mark/Jarrod said would work, I just wish I could store it as a CRGB so I could use s.color in my code without having to do casts everywhere.
I have actually hacked together a IntelHex formatted .eep builder that is now used in my build scripts. This way I can choose what exactly is stored in the eeprom. It’s probably a little overkill for this application, but I figure it could be used some form of graphical settings editor for users in the future.
I actually don’t have addressable led strips yet, I am just using FastLED for most of it’s math (HSV, corrections, etc). So with only a few colors that method may work well.
