Has anyone run into this?
I am printing really slow, 20mm, and while I was able to print a 20x20mm cube just fine, trying to print a 100mm calibration object, in any orientation, gives the same error below (as seen in octoprint terminal):
“Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.”
I downloaded a plugin that was supposed to send OK rec to by pass this, I turned up the time out to 60 seconds from the stock 30. I am not sure what to do here. Any ideas? Am I even right thinking this is a printing too slow thing?
I think other have had this problem and Elias just posted that they think extending the stepper watchdog timeout fixes the problem. If you are not of the slack channel you should sign up.
I’ve hopped on the freenode IRC a few times to get my printer this far, not sure I’ve heard about the slack channel, if that is different.
Was a walk through or patch in the works?
I think it shows at the top of the freenode Welcome and on the wiki.
@Philip_Acierto I think one of the issues is a simple configuration change from what I remember.
alright, I’ll dig around for it. I didn’t see it in the config but I would hope its something simple to change like that.
Yes, increase the timeout in OctoPrint as well as the stepper watchdog timeout in Redeem.
@Elias_Bakken I replied to the slack channel as well, but:
adjusting the watchdog timeout and octoprint doesn’t seem to be fixing my slow move issues. I am fairly certain the issue is still timeout related because if I speed up my print speed, it no longer happens (though a longer movement input will still trip it)
I have tried turning up the timeout_seconds = 500, put it up to 1000, and 5000. I’ve changed Communication timeout to 500, 5000, and nothing seems to change. The print head moves, and completes the last movement sucesffuly, but never return Recv: ok, so the next move is never issues.
Send: N867 G1 X43.440 Y87.563 E184.965480
Recv: ok
Send: N868 G1 X83.533 Y127.656 E186.8513107
Recv: ok
Recv: ok
Send: N869 M10532
Send: N870 G1 X82.967 Y127.656 E186.8701111
Recv: ok T:187.0/190.0 T1:0.0/0.0 T0:187.0/190.0 B:0.0/0.0 @:255.0
Send: N871 G1 X43.440 Y88.129 E188.7293*95
Any other ideas?
https://plus.google.com/photos/111974602640488998735/albums/6331771357297256513/6331771354771395746
Here is a video and the terminal output (with it hanging at the end for about 5 mins before displaying the timeout error)
Send: N1068 G1 X113.223 Y124.536 E8.9527107
Recv: ok
Send: N1069 G1 X113.788 Y124.536 E8.9715109
Recv: ok
Send: N1070 G1 X116.908 Y127.656 E9.118396
Recv: ok
Send: N1071 G1 X117.474 Y127.656 E9.1371105
Recv: ok
Send: N1072 G1 X114.354 Y124.536 E9.2839110
Recv: ok
Send: N1073 G1 X114.920 Y124.536 E9.302796
Recv: ok
Send: N1074 G1 X118.040 Y127.656 E9.4494105
Recv: ok
Send: N1075 G1 X118.606 Y127.656 E9.4682105
Recv: ok
Send: N1076 G1 X115.486 Y124.536 E9.615097
Recv: ok
Send: N1077 G1 X116.051 Y124.536 E9.633897
Recv: ok
Send: N1078 G1 X119.171 Y127.656 E9.780699
Recv: ok
Send: N1079 G1 X119.737 Y127.656 E9.7994108
Recv: ok
Send: N1080 G1 X116.479 Y124.399 E9.952698
Recv: ok
Send: N1081 G1 X116.843 Y124.197 E9.9665110
https://plus.google.com/photos/111974602640488998735/albums/6331784506322603761/6331784511391895058
