Has anyone purchased this 12V heater mat from RobotDigg?
I assumed I could plug this into my RAMPS board like a standard heated bed but the large polyfuse on the board got very hot and stopped powering the mat. Should I try modding my board and replace the polyfuse with a wire? Would I be able to run this mat on 120V with a SSR?
And 30 minutes after posting this I realized I had the bed hooked up to the wrong port on my RAMPS board. I was running the bed off the extruder heater port and was tripping the small polyfuse not the large one. Problem solved and this mat is working perfectly.
I have been using the 120V AC silicon heater mats from Alirubber on Aliexpress for a long time. They have always performed great for me. Cost is only like $35 and you can specify everything you want about them and they are built to order. I made mine for HercuLien 800W, 120V, 380X380mm, dual thermistors (in case one failed), 1.5M cable length for routing to the SSR.
The poly fuses on the lower cost RAMPS sometimes aren’t up to spec. You can try to replace it with a like rating (specs in the reprap wiki for RAMPS) or replace the fuse entirely with an automotive type fuse and holder.
@Ted_Huntington I’m not sure. After I fixed my problem I ran a PID autotune to 90C which seemed to have heated up a lot faster than my other printer’s MK2 heater bed. I’m about to mount my mat and a sheet of PEI to my aluminum bed so I’ll see if I can run some timed tests tomorrow.
@Chirag_Patel I use 120V (the mains in the US) and for a 300x300mm 500w heating pad it usually heats up to 120C in under 10 minutes, and I wonder if the 12V version can heat up that quickly with 12V.
@Chirag_Patel , I recommend wiring your 12v positive lead directly to your power supply. wire the negative leat to the RAMPS for switching. This bypasses the fuse and all those tiny little circuits. I did this more than a year ago for all my heaters by recommendation from a reprap irc member and it’s solved all the polyfuse problems inherent to the RAMPS.
The cheaper RAMPS polyfuses might be OK with 12V. At 24V it might be an issue because sometimes the assembler cuts corners and uses 16V polyfuses.
I did the Alirubber route too. Custom built to a custom layout per blueprint. Wiring length & type to request. Added a second thermistor for free or $1 more (I forget). Did dual voltage to my request too, rewire it from parallel to series to work with double the voltage. I bought a spare heater incase I screwed up the first. I think it took them 3 days to fabricate. It’s been working great, but maybe only 50 hours of power applied so far.
@Eclsnowman Do you run the printer power supply and the heated bed on the same house circuit. What does an 800W heater plus a the printer power supply get for its peak current? My math can get to 20 amps, but I don’t think switching power supplies work they way I think they do. i.e. Does a 24V DC, 400W power supply pull 16.66 amps from the supply side? And if not, how do you get to 400W. I guess I’m asking, how big can you go on your heater in Watts?
@Chris_Brent
What is your mains voltage? If 120VAC, the bed takes 6.7A peak. It’s only full on for warmup. The rest of the 3D printer probably only adds another amp, so I would say maybe 8A peak for planning. Average current might not even be half that when it’s up and running.
Yeah, on my HercuLien I was running the bed at 24V originally. Hence why I have such a high power PSU on it. But to be honest now that the bed runs at mains a 250W would more than take care of two 40W heaters and 5 steppers.
So I also got concerned because I lived most of my live in 240VAC countries, which usually have 10 or 11 Amp fuses. I only just realized my circuit breakers here in 110VAC land are 20 amp!
