Has anyone posted a CAD model of the recommended ball screws anywhere?
Just added a few thing for you to the github. Should get you going: https://github.com/eclsnowman/Eustathios-Spider-V2/tree/master/Community%20Mods%20and%20Upgrades/walterhsiao/1204%20Ballscrew%20Bed%20Support/Eustathios%20Ball%20Screw%20Model%20Files
I think you will notice the ball screw model is slightly shorter. That’s because on the Eustahtios Spider V1 (and V1.5 which is what I call mine because its half converted into a V2) was before I dropped the floor down to gain extra Z. I noted this in the PDF print in that directory. But if you can open the solidworks 2015 file you can change the length to whatever you need.
Thank you. The Golmart listing doesn’t show or describe the end thread. Is that a problem? Or do you just send them the PDF to tell them what you want?
I added it later. You can use it as they have it listed with a 8mm ID collar on the bottom. But I like using a nylock nut on the bottom instead.
Yeah just send them the PDF, price shouldn’t change.
