Has anyone ever used Nylon Bridge for high mechanical abrasion situations?
I want to print (dont know the exact translation sorry) a series of plates for Farming, the ones used on seeders for grain sorghum, and they are allways under stress and have the tendency to wear over time, at first I think of Petg but nylon seems to have more resistance to abrasion, what i dont like its the Tc temp of 52c… for nylon bridge, so im kinda lost,
Any ideas or someone ever try something like this?
Nylon is usually a good choice for abrasion applications. Don’t know about Bridge specifically some of the stuff that makes it lower-warp (low crystallinity) might also make it stickier, but I’m speculating.
If you want something that handles wear crazy well, take a look at iglidur it’s spendy, and sometimes tricky to print, but it is a phenomenal bearing material
if it’s being abraded by seeds being sown, you’re introducing the plastic in very small particles to your field each time. not sure that is a great idea for your long term soil and crop quality.
I use alloyy 910 for that. Holds up 4 month now instead of abs which held up 2 weeks… I think nylon is the best choise for low frictionstuff. At least its printable
@AlohaMilton you do that with you coffeemachine. You do it with your car, you do it with every moving part. Just think how fields are on roadsides and you get all the rubber, metals, plastics, chemicals and oil into the field…
@AlohaMilton actually the standart is abs for this kind of plates, and like @VolksTrieb as stated nylon is best for friction, but wasnt sure for this kind of application, will try to print and see what happends
I do not slowly grind down and distribute plastics into topsoil with my coffee machine. and no, most crop fields are not full of that stuff you imagine. what the heck? farming is hard enough one first starts to condition and improve the soil quality, first thing! For more crops! to pay the mortgage! sheesh the public concept of farming is so bad, you think you can survive without farmers? think again!
I thought you were cool, I was so wrong. basically accept anything as long as in the moment its not directly negative to you. screw the planet that gave birth to you eh? fucking disaster, the attitude that if others do something bad your allowed to do worse. thought people in this community would be somehow not trolls grabbing at the latest trend. was wrong, still searching for humans with heart.
@AlohaMilton ok my friend you are seriusly of the tracks now,
first this place its for 3d printing only,
second as 3th generation farmer i know what and what not fucks the farmings lands, i do FULL ORGANIC crops, no pesticides no gmos, we barely accept certains hybrids in my land, the use of nylon its to stop using the abs standart, im trying to improve the production AND do reforestation of the lands, less used land for farming more land for trees that stop desertification of the land, here in mexico we have that problem a lot, so plz stop making a problem from all the propaganda you have seen on the news, do something for real and dont argue with other people, theres enought hate already out there for nonsenses.
@AlohaMilton aww man just go flip peoples words and lie. Nobody said fuck the planet and the planet did not give birth to me. I never said that Iam allowed to do it worse. Nobody did. Just go ahead and show everyone that Iam that bad you lttl pssy… You are no way realistic at all. If you want this lifestyle then there is no way of green everything. You will do harm to the climate and to your enviroment. There is no way out. No civilization will go from picking trees to hightech cyborg without fckin around with it. It will not happen. There is no god you know of and the planet will survive us. It will…
