Has anyone cut plexiglass yet on the FABkit? What thicknesses and speeds?
What thicknesses and speeds? (Just trying to figure out the options)
Should be able to go up to 6 to 8 mm. Only really use 3mm as its expensive stuff. Try around 10mm/s at 100 percent for starters.
10mms/100% is for 3mm?
I know it is expensive, but sometimes you want to have rigid parts from ‘plastic’, and then Plexi (Acrylic) just makes sense!
In my experience the acrylic varies. So you need to find out best settings per supplier. We are going to start stocking material with settings soon :slight_smile:
