Has anyone an idea of how use the exhaust as reflow to air assist? No more compressors
Passing the air through a carbon filter, such as that used in cars as a filter of habitaculo. To re-introduce the air again in the machine for a new orifice. Is it what thinking these?
Yees
It is what some extractor bells do when it has not gone out of gases in the kitchen. You lose something of efficiency for crossing the filter. Make a box with a 3d or buy a second hand filter box in a chop shop (desguace)
Yes, I was wondering if any physics effect (Venturi, etc) could help to better implement ‘turbo’ effect.
forget it. Venturi is more to add an aditive, no for get more flow.
If what you want is a major effect of sweep, a mouthpiece of exit uses type duck billed, smoothed and very broad, it gets more speed of air exit
si te quieres entretener leyendo: http://www.airflow.es/descargas/manual/manualDifusion.pdf
Probably obtain some improvement with the effect coanda, directing the air jet the flat table to drag more air and to recover (get back) part of the flow lost for crossing the filter.
Hoy me siento inspirado
If you want to increase x4 the air flow, and you have compressor, the effect coanda can help with this SMC’s element.
Woow. I will take a look
thanks!!
