Hangup with S3D files - a survey
Hi all,
I experimented sudden board hangup/not responsive behavior with some S3D files. I tried wolfmanjm hack but still no relief.
Problem arises with S3D generated files, probably because of his great quantity of small (1 micro step ?!? looking for troubles…) moves.
After many hours of debugging, I think I have found something to share in this forum.
When a move has finished (last step sent to a motor) StepTicker::TIMER0_IRQHandler schedules a PendSV_IRQHandler interrupt service.
During PendSV_IRQHandler (300us ?) a lot of callbacks gets invoked, namely StepperMotor::signal_move_finished. This routine frees old movement block and (if there is a fresh block ready) schedules a new move, adding the motor to stepTicker active motor list.
BUT: if in meanwhile StepTicker::TIMER0_IRQHandler is called again (his priority is higher than PendSV) in some conditions motor gets removed from active list. I guess this happens with VERY SHORT moves (that start and end while PendSV is still being serviced ?)
As a result, we have x steps to make and no motor to service them, so board hangs up. At least, this is what I discovered thanks to a stroke of luck (a file that hangs my printer always at the same line)
I tried to stop TIMER0 while servicing PendSV and restart immediately before exiting. Now my printer is printing correctly.
I don’t know if stopping the 10us IRQ during PendSV can lead to other problems…surely I cannot perceive the 300 us delays.
Any comments ?
Imported from wikidot
Disabling timer0 is not an option it is needed to keep running so we know how many ticks are missed while processing the end of block, and can be compensated for.
It is expected that ticks will occur while still processing the previous end of block, and if you look at the top of stepermotor::tick() you will see it would be ignored if still processing a previous end of block. That was the whole reason for deferring to pendsv to process that.
a motor is only removed from active motors list if it has no more moves pending, and that is correct too. the system is atomic so it is safe to do so even while stepticker is running.
I suspect it was just a fluke or side effect that you mitigated the hang by turning off stepticker, however as i said that is not an option.
