Had to reinstall ubuntu mate, and all my software was lost...
Had to reinstall ubuntu mate, and all my software was lost… after reinstalling LW4 i can do gcode fine, but if i try to do a png file, the steppers run as they should, but the laser does not fire… it’s probably something simple i missed :confused:
Does it happens with cut operations also? What board are you using? Remember to select your type of board from the machine profiles in settings. This will load the appropriate gcode commands to turn the laser on/off
never mind, found the problem :stuck_out_tongue:
I’m not even sure i want to share it… face palm :smiley:
@ATN11 laser was disconnected?
Nope… Worse… The item i was to burn had an empty edge… So it started running but as it was not suppose to fire, it did not… :roll_eyes::smirk:
