Had to about murder the airtripper, but I have it assembled and attached to the #makibox. Let’s see if my mangled and modified v3 can out last the #makible zen drive. Pics and details to follow.
I used fold back clip to put it on the rear right side for temporary use as it is part of my next printer.
I have an arduino starter kit box that fits perfectly in the back of the printer. Then I bolted the drive to that. I had to do some serious modifications to the airtripper so the idler wheel does not apply as much tension as I’d like. Tho it does turn where the @Makible zen wheel does not.
Had to modify it because I’m using the stock gear Makible provided
