Guys, im having tons of troubles to print this:
https://docs.google.com/file/d/0ByUR_hnaHe8xUnNnZ01xcnJDOGc/edit?usp=sharing
any hint?
any hint?
If you’re using an FDM/FFF machine, easiest thing would be to split it in two then glue the parts together afterwards…
If you really don’t want to do that or are using some other process, you’ll need to use support structures.
