Guys , I need you to take a look at this programming that i
Guys , I need you to take a look at this programming that i have been working with Inventables trying to get me shapeoko2 up and running . the z seems to be working ok, x seems to working ok but the motor does not sound the same as it did before . the y is now on motor 2 and 4 and is moving the right way but does not sound the same as before and is moving slower . please let me know your thoughts . thanks
motor 1=x with a nema 23 /20 tooth 2 deg pitch
motor 2=Y with a nema 23 /20 tooth 2 deg pitch
motor 3= z with a nema 17 /20 tooth 2 deg pitch
motor 4 =Y with a nema 23/20 tooth 2 deg pitch
{“ej”:""}
[fb] firmware build 438.02
[fv] firmware version 0.97
[hp] hardware platform 1.00
[hv] hardware version 8.00
[id] TinyG ID 3X3566-UUR
[ja] junction acceleration 100000 mm
[ct] chordal tolerance 0.0100 mm
[sl] soft limit enable 0
[st] switch type 0 [0=NO,1=NC]
[mt] motor idle timeout 2.00 Sec
[ej] enable json mode 0 [0=text,1=JSON]
[jv] json verbosity 1 [0=silent,1=footer,2=messages,3=configs,4=linenum,5=verbose]
[js] json serialize style 1 [0=relaxed,1=strict]
[tv] text verbosity 1 [0=silent,1=verbose]
[qv] queue report verbosity 2 [0=off,1=single,2=triple]
[sv] status report verbosity 1 [0=off,1=filtered,2=verbose]
[si] status interval 250 ms
[ec] expand LF to CRLF on TX 0 [0=off,1=on]
[ee] enable echo 0 [0=off,1=on]
[ex] enable flow control 1 [0=off,1=XON/XOFF, 2=RTS/CTS]
[baud] USB baud rate 5 [1=9600,2=19200,3=38400,4=57600,5=115200,6=230400]
[net] network mode 0 [0=master]
[gpl] default gcode plane 0 [0=G17,1=G18,2=G19]
[gun] default gcode units mode 1 [0=G20,1=G21]
[gco] default gcode coord system 1 [1-6 (G54-G59)]
[gpa] default gcode path control 2 [0=G61,1=G61.1,2=G64]
[gdi] default gcode distance mode 0 [0=G90,1=G91]
[1ma] m1 map to axis 0 [0=X,1=Y,2=Z…]
[1sa] m1 step angle 1.800 deg
[1tr] m1 travel per revolution 40.0000 mm
[1mi] m1 microsteps 8 [1,2,4,8]
[1po] m1 polarity 0 [0=normal,1=reverse]
[1pm] m1 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving]
[2ma] m2 map to axis 1 [0=X,1=Y,2=Z…]
[2sa] m2 step angle 1.800 deg
[2tr] m2 travel per revolution 40.0000 mm
[2mi] m2 microsteps 8 [1,2,4,8]
[2po] m2 polarity 0 [0=normal,1=reverse]
[2pm] m2 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving]
[3ma] m3 map to axis 2 [0=X,1=Y,2=Z…]
[3sa] m3 step angle 1.800 deg
[3tr] m3 travel per revolution 1.2500 mm
[3mi] m3 microsteps 2 [1,2,4,8]
[3po] m3 polarity 0 [0=normal,1=reverse]
[3pm] m3 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving]
[4ma] m4 map to axis 1 [0=X,1=Y,2=Z…]
[4sa] m4 step angle 1.800 deg
[4tr] m4 travel per revolution 40.0000 mm
[4mi] m4 microsteps 1 [1,2,4,8]
[4po] m4 polarity 1 [0=normal,1=reverse]
[4pm] m4 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving]
[xam] x axis mode 1 [standard]
[xvm] x velocity maximum 800 mm/min
[xfr] x feedrate maximum 800 mm/min
[xtn] x travel minimum 0.000 mm
[xtm] x travel maximum 350.000 mm
[xjm] x jerk maximum 20 mm/min^3 * 1 million
[xjh] x jerk homing 20 mm/min^3 * 1 million
[xjd] x junction deviation 0.0500 mm (larger is faster)
[xsn] x switch min 1 [0=off,1=homing,2=limit,3=limit+homing]
[xsx] x switch max 0 [0=off,1=homing,2=limit,3=limit+homing]
[xsv] x search velocity 500 mm/min
[xlv] x latch velocity 100 mm/min
[xlb] x latch backoff 5.000 mm
[xzb] x zero backoff 1.000 mm
[yam] y axis mode 1 [standard]
[yvm] y velocity maximum 800 mm/min
[yfr] y feedrate maximum 800 mm/min
[ytn] y travel minimum 0.000 mm
[ytm] y travel maximum 350.000 mm
[yjm] y jerk maximum 20 mm/min^3 * 1 million
[yjh] y jerk homing 20 mm/min^3 * 1 million
[yjd] y junction deviation 0.0500 mm (larger is faster)
[ysn] y switch min 1 [0=off,1=homing,2=limit,3=limit+homing]
[ysx] y switch max 0 [0=off,1=homing,2=limit,3=limit+homing]
[ysv] y search velocity 500 mm/min
[ylv] y latch velocity 100 mm/min
[ylb] y latch backoff 5.000 mm
[yzb] y zero backoff 1.000 mm
[zam] z axis mode 1 [standard]
[zvm] z velocity maximum 800 mm/min
[zfr] z feedrate maximum 800 mm/min
[ztn] z travel minimum 0.000 mm
[ztm] z travel maximum 75.000 mm
[zjm] z jerk maximum 20 mm/min^3 * 1 million
[zjh] z jerk homing 20 mm/min^3 * 1 million
[zjd] z junction deviation 0.0500 mm (larger is faster)
[zsn] z switch min 0 [0=off,1=homing,2=limit,3=limit+homing]
[zsx] z switch max 1 [0=off,1=homing,2=limit,3=limit+homing]
[zsv] z search velocity 400 mm/min
[zlv] z latch velocity 100 mm/min
[zlb] z latch backoff 5.000 mm
[zzb] z zero backoff 1.000 mm
[aam] a axis mode 3 [radius]
[avm] a velocity maximum 230400 deg/min
[afr] a feedrate maximum 230400 deg/min
[atn] a travel minimum -1.000 deg
[atm] a travel maximum -1.000 deg
[ajm] a jerk maximum 5760 deg/min^3 * 1 million
[ajh] a jerk homing 5760 deg/min^3 * 1 million
[ajd] a junction deviation 0.0500 deg (larger is faster)
[ara] a radius value 0.1989 deg
[asn] a switch min 1 [0=off,1=homing,2=limit,3=limit+homing]
[asx] a switch max 0 [0=off,1=homing,2=limit,3=limit+homing]
[asv] a search velocity 600 deg/min
[alv] a latch velocity 100 deg/min
[alb] a latch backoff 5.000 deg
[azb] a zero backoff 2.000 deg
[bam] b axis mode 0 [disabled]
[bvm] b velocity maximum 3600 deg/min
[bfr] b feedrate maximum 3600 deg/min
[btn] b travel minimum -1.000 deg
[btm] b travel maximum -1.000 deg
[bjm] b jerk maximum 20 deg/min^3 * 1 million
[bjd] b junction deviation 0.0500 deg (larger is faster)
[bra] b radius value 1.0000 deg
[cam] c axis mode 0 [disabled]
[cvm] c velocity maximum 3600 deg/min
[cfr] c feedrate maximum 3600 deg/min
[ctn] c travel minimum -1.000 deg
[ctm] c travel maximum -1.000 deg
[cjm] c jerk maximum 20 deg/min^3 * 1 million
[cjd] c junction deviation 0.0500 deg (larger is faster)
[cra] c radius value 1.0000 deg
[p1frq] pwm frequency 100 Hz
[p1csl] pwm cw speed lo 1000 RPM
[p1csh] pwm cw speed hi 2000 RPM
[p1cpl] pwm cw phase lo 0.125 [0…1]
[p1cph] pwm cw phase hi 0.200 [0…1]
[p1wsl] pwm ccw speed lo 1000 RPM
[p1wsh] pwm ccw speed hi 2000 RPM
[p1wpl] pwm ccw phase lo 0.125 [0…1]
[p1wph] pwm ccw phase hi 0.200 [0…1]
[p1pof] pwm phase off 0.100 [0…1]
[g54x] g54 x offset 0.000 mm
[g54y] g54 y offset 0.000 mm
[g54z] g54 z offset 0.000 mm
[g54a] g54 a offset 0.000 deg
[g54b] g54 b offset 0.000 deg
[g54c] g54 c offset 0.000 deg
[g55x] g55 x offset 75.000 mm
[g55y] g55 y offset 75.000 mm
[g55z] g55 z offset 0.000 mm
[g55a] g55 a offset 0.000 deg
[g55b] g55 b offset 0.000 deg
[g55c] g55 c offset 0.000 deg
[g56x] g56 x offset 0.000 mm
[g56y] g56 y offset 0.000 mm
[g56z] g56 z offset 0.000 mm
[g56a] g56 a offset 0.000 deg
[g56b] g56 b offset 0.000 deg
[g56c] g56 c offset 0.000 deg
[g57x] g57 x offset 0.000 mm
[g57y] g57 y offset 0.000 mm
[g57z] g57 z offset 0.000 mm
[g57a] g57 a offset 0.000 deg
[g57b] g57 b offset 0.000 deg
[g57c] g57 c offset 0.000 deg
[g58x] g58 x offset 0.000 mm
[g58y] g58 y offset 0.000 mm
[g58z] g58 z offset 0.000 mm
[g58a] g58 a offset 0.000 deg
[g58b] g58 b offset 0.000 deg
[g58c] g58 c offset 0.000 deg
[g59x] g59 x offset 0.000 mm
[g59y] g59 y offset 0.000 mm
[g59z] g59 z offset 0.000 mm
[g59a] g59 a offset 0.000 deg
[g59b] g59 b offset 0.000 deg
[g59c] g59 c offset 0.000 deg
[g92x] g92 x offset 0.000 mm
[g92y] g92 y offset 0.000 mm
[g92z] g92 z offset 0.000 mm
[g92a] g92 a offset 0.000 deg
[g92b] g92 b offset 0.000 deg
[g92c] g92 c offset 0.000 deg
[g28x] g28 x position 0.000 mm
[g28y] g28 y position 0.000 mm
[g28z] g28 z position 0.000 mm
[g28a] g28 a position 0.000 deg
[g28b] g28 b position 0.000 deg
[g28c] g28 c position 0.000 deg
[g30x] g30 x position 0.000 mm
[g30y] g30 y position 0.000 mm
[g30z] g30 z position 0.000 mm
[g30a] g30 a position 0.000 deg
[g30b] g30 b position 0.000 deg
[g30c] g30 c position 0.000 deg
tinyg [mm] ok>
Kurtflys
Nothing jumps out from looking at these, very hard to read this parameter list in this page format.
I would say your $xjm and $yjm values are low, more typically = 5000. That might add to your perception of “slow”, not sure where you were set ‘before’
What commands are you using to create movement?
G0, G1, or are you jogging with CP?
AT this point just using jogging , we did try to import a file and run it and was able to import it but we could not get the shapeoko to respond to the gcode . i am sitting here go throw line by line looking at the code and comparing it to my old settings . I do think that it is a problem with the gcode , because the problem is still there just using the jogg . i will look at what you told me to look at and do you think that I should move that up ?
xjm and yjm will only speed things up.
Tryzeroing your machine in a safe area.
then try to move with the following command in the Serial Port Console command line: “G21 G0 X10”
That should move X axis 10mm
Then “G21 G0 Y10”
That should move Y 10 mm.
Then “G21 G0 Z10”
Z should move up 10 mm.
report back
We have new news , it is alive!!!
