Guys i need some advice on troubleshooting my 3020 laser. Yesterday during a job the laser stopped firing a beam .
it doesnt fire at all no matter which button ( CP or LPS) . is there anyway to identify the damaged part. i hope it is only a bridge rectifier but it seems to be that high voltage transformer. Anyway i ll check the rectifier but i was wondering if i have to remove it from the pcb to check it with a multimeter
Is there anyway to tell if it is the tube or the flyback transformer ?
No noise . i cant hear not a single thing or arching sounds or even the old working beam noise. my amp meter doesn’t show anything too . i also checked the ground connection.
Typically if the tube is dead a good lps may arc near the anode.
It’s hard to isolate tube vs lps failures.
Your symptoms sound like a bad hvt.
You can tape a grounded wire to the tube, near the anode. Not connected to it. Then get away from the tube and pulse the test switch on lps to see if the anode arcs to the ground wire.
This is dangerous, stay well away from the tube while you test.
You can replace the hvt, but these supplies are not expensive to replace.
Sorry you 've answered already…
do you suggest any shop in europe to get a decent lps ? i want to measure the bridge rectifier can i just unplug the 3 wires that go into the HVT ?
Thanks for helping btw…
