Guys , I just installed a Reprap Graphic Smart Controller and its working fine. I am trying to move my Z Axis 0.1mm up or maybe down.
I can not find the menu for this move while the print is printing. There is menu that shows Babysteps ??
Not while printing, Maybe if you pause the print. but as soon as you start I think it will move to where it was. It also depends on firmware.
babysteps is what you’re looking for.
Ok I am using Marlin. When my print starts its a little too low, so I like to lift somewhat till head is at correct height. Yes I know I must set my height correct in the beginning.
How do you use the babystep ? I go to the menu , but it show no numbers 0.10mm etc or direction ( up or down ) ?
Thanks guys , I try that.
