Guys, I got the new build completed for Pegasus Aviation,
Guys, I got the new build completed for Pegasus Aviation, But when I connected the new M1 board that Im unfamiliar with and try to connect via ChiliPeppr… the monitor shows a repeating error (9) message with scrolling 0,0,0 cords. Any clue? Ive got grbl set as post processor and 115200 baud rate. tried other baud rates but I get a yellow ? and no reponse to commands.
By the time I got it done, Brandon had already left for the weekend… any help would be great
Are you sure you have serial port json server running? Are you using the correct Grbl workspace?
http://chilipeppr.com/grbl
@Eclsnowman I think That is what I did Wrong Eric. I noticed after I posted that when I hit my bookmark it went to the TinyG extension of the chilipeppr site. Im back in Arizona for the weekend so I cant check it till I get back to work on tuesday. Thanks bro.
and yes The json server was running and confirmed com 5 when I started the program.
Glad to help
Also, the Chilipeppr group is very responsive.
