Grrr... just updated to fasted 3.0.1, deleted the old versions,
Grrr… just updated to fasted 3.0.1, deleted the old versions, rebooted arduino software and run the blink sketch… and then follows the longest error I’ve ever seen!
must be a simple problem! using teensy 3.0, teensy uploader is kicking in, and same result when using tty or cu (whatever they are! :: LOL ::)
any ideas?
This report would have more information with
“Show verbose output during compilation”
enabled in File > Preferences.
Arduino: 1.0.5 (Mac OS X), Board: “Teensy 3.0”
In file included from /Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi.h:50:0,
from /Users/kelvinmead/Documents/Arduino/libraries/FastLED/FastLED.h:29,
from Blink.ino:1:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::update_ctar0(uint32_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:121:17: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:121:17: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:121:17: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:121:43: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:122:28: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:122:28: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:122:28: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:124:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:124:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:126:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:126:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:127:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:127:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:129:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:129:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::update_ctar1(uint32_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:134:17: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:134:17: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:134:17: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:134:43: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:135:28: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:135:28: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:135:28: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:137:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:137:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:139:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:139:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:140:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:140:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:141:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:141:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In member function ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::init()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:194:7: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:194:13: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:194:14: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:198:5: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:198:5: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:200:20: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:200:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:201:17: error: ‘SIM_SCGC6_SPI1’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:204:5: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:204:5: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:210:3: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:210:3: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:210:3: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:211:3: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:211:3: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::waitFully()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:217:11: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:217:11: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:217:11: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:217:33: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:218:12: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:218:12: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:218:12: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:218:34: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:219:3: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:219:3: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:219:3: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static bool ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::needwait()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:222:66: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:222:66: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:222:66: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:222:83: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::wait()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:223:62: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:223:62: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:223:62: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:223:81: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::wait1()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:224:63: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:224:63: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:224:63: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:224:91: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeWord(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:241:4: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:241:4: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:241:4: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeByte(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:249:4: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:249:4: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:249:4: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeWord(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:256:77: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:256:77: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:256:77: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeWordNoWait(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:257:75: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:257:75: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:257:75: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByte(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:259:76: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:259:76: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:259:76: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeBytePostWait(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:260:76: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:260:76: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:260:76: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByteNoWait(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:261:74: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:261:74: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:261:74: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeWordCont(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:263:81: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:263:81: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:263:81: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeWordContNoWait(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:264:79: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:264:79: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:264:79: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByteCont(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:266:80: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:266:80: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:266:80: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByteContPostWait(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:267:80: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:267:80: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:267:80: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByteContNoWait(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:268:78: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:268:78: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:268:78: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeBit(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:272:25: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:272:25: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:272:25: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In member function ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writePixels(PixelController<RGB_ORDER>)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:351:26: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:351:26: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:351:26: error: expected ‘)’ before ‘pSPIX’
ahh, ok. reinstalled arduino (1.0.6), reinstalled teensyduino, reinstalled teensy boot loader and all seems to be working.
not sure if it was a 1.0.5 issue, or just my mac being weird.
saved for posterity.
Yeah - that error is a teensyduino error - reinstalling teensyduino to most recent is what most likely fixed it.
