Greeting, I join the group recently.
Greeting, I join the group recently. Now I’m planing to sourcing the parts for my build of Eustathios Spider V2. While my build will stick to the plan most of the parts, I wonder if upgrade the Z Axis timing belt to 2GT-10mm will gain any advantage? Or is it just a waste to upgrade it? Thanks.
If you need a Mc Master project order for all the hardware sourced through it, let me know. I can provide part lists for all the sellers I used, but I’m sure you can find cheeper, esp if you order all the screws from a cheaper source. Be sure to get at least 15 drop in t nuts! You’ll thank me later :stuck_out_tongue:
Also, I would suggest doing @Walter_Hsiao 's ballscrew, bed and carriage upgrade.
@Stefano_Pagani Thank you for the info. And yes, I plan to use 1204 ball screw.
