Grbl Settings
$$ - View Grbl settings
To view the settings, type $$ and press enter after connecting to Grbl. Grbl should respond with a list of the current system settings, as shown in the example below. All of these settings are persistent and kept in EEPROM, so if you power down, these will be loaded back up the next time you power up your Arduino.
The x of $x=val indicates a particular setting, while val is the setting value. In prior versions of Grbl, each setting had a description next to it in () parentheses, but Grbl v1.1+ no longer includes them unfortunately. This was done to free up precious flash memory to add the new features available in v1.1. However, most good GUIs will help out by attaching descriptions for you, so you know what you are looking at.
Settings and sample values Description
$0=10 Step pulse, microseconds
$1=25 Step idle delay, milliseconds
$2=0 Step port invert, mask
$3=0 Direction port invert, mask
$4=0 Step enable invert, boolean
$5=0 Limit pins invert, boolean
$6=0 Probe pin invert, boolean
$10=1 Status report, mask
$11=0.010 Junction deviation, mm
$12=0.002 Arc tolerance, mm
$13=0 Report inches, boolean
$20=0 Soft limits, boolean
$21=0 Hard limits, boolean
$22=1 Homing cycle, boolean
$23=0 Homing dir invert, mask
$24=25.000 Homing feed, mm/min
$25=500.000 Homing seek, mm/min
$26=250 Homing debounce, milliseconds
$27=1.000 Homing pull-off, mm
$30=1000. Max spindle speed, RPM
$31=0. Min spindle speed, RPM
$32=0 Laser mode, boolean
$100=250.000 X steps/mm
$101=250.000 Y steps/mm
$102=250.000 Z steps/mm
$110=500.000 X Max rate, mm/min
$111=500.000 Y Max rate, mm/min
$112=500.000 Z Max rate, mm/min
$120=10.000 X Acceleration, mm/sec^2
$121=10.000 Y Acceleration, mm/sec^2
$122=10.000 Z Acceleration, mm/sec^2
$130=200.000 X Max travel, mm
$131=200.000 Y Max travel, mm
$132=200.000 Z Max travel, mm
$x=val - Save Grbl setting
The $x=val command saves or alters a Grbl setting, which can be done manually by sending this command when connected to Grbl through a serial terminal program, but most Grbl GUIs will do this for you as a user-friendly feature.
To manually change e.g. the microseconds step pulse option to 10us you would type this, followed by an enter:
$0=10
If everything went well, Grbl will respond with an ‘ok’ and this setting is stored in EEPROM and will be retained forever or until you change them. You can check if Grbl has received and stored your setting correctly by typing $$ to view the system settings again.
