Got motor and modified prop mounted in the lift nacele.
Got motor and modified prop mounted in the lift nacele. Did a dry fit in the the body of the craft and it looks good.
What will be the end product?
NICE!
Nice, looks a lot better than my RC prints. Is it a VTOL plane with in wing motors?
One thing you might want to tweak is that the prop seems a bit high up to gain any efficiency and protection from the housing. If you drop it slightly lower you’ll get better thrust output and probably avoid the issue of prop damage from tipping.
Hovercraft? VRTOL?
Will it be full of eels?
