Google+ post by Stefan Arnautu on 2017-11-23 16:23:06 UTC
Print 3D
Can you tell more about the print? What printer was it made with? How did you generate it? This sounds like a great idea for a Christmas gift
I’m going to do one of these for my next project.
@Justin_Nesselrotte Don’t know if this is how this particular print was made (this one looks curved) but if you drag and drop any grey scale image into Cura you will get options to create a flat lithophane.
Please do share more information, it looks amazing.
Good one! Are they made from one single color or are they printed dual using some lighting effect caused by the layers? I am not that deep into lithophane printing.
@Daniel_Stauffer The Lithophanes typically use a single filament color and when they print the darker areas are thicker (taller) than the light areas. Looks like a 3D topographical map. You can have the rough side or the smooth side facing out. When lit from behind the image appears.
@Jeff_Parish ah great. So actually having the light reflected through the different layer sizes.
best for lithophane
http://3dp.rocks/lithophane/
