Print Problems.
First printing with Replicape?
I have some print problems with the first setup. First problem print pulls threads. Second problem I do have gaps between the infill and the perimeters but I do not know why.
At one picture you can see the first layer => is it possible that I have a little bit over extrusion here?
Yes with replicape and slic3r but I do not know what´s wrong.
Steps per mm are correctly for steppers?
You should try to hit up https://groups.google.com/forum/#!forum/deltabot with that and see what they say - a lot of knowledgeable people over there.
http://googlegroups.com
