Google+ post by Joseph Ronie on 2018-07-06 01:54:39 UTC
It is early.
I need to get one…
It is my thrid 3d printer. Made a hypercube and a cheep i3 knockoff. Now for the real deal.
Do not, I repeat do not tighten the x idler screw to seat the m3 nylock as instructed :grinning: it will rip the screw head through garunteed. The user comments form each step are worth reading before doing the step.
Thank you fir the heads up.
Hi
I am from India looking to buy one can someone help me startup plz
@Mohammed_Tabrez_Khan https://www.prusa3d.com/
Where in India are you located,
Having built two so far: there is one part in the build process where the nut and bolt you need are actually in the package for the next stage – so don’t panic when you get to that point (easiest to simply take them from the spares bag Prusa so thoughtfully provide).
Oh, and I suggest removing the protective plastic from the little screen before fitting it in its box, then sticking it back on again immediately you’ve done so (to protect it during the rest of the build) – otherwise it can be v. difficult to get it off later.
@Mohammed_Tabrez_Khan You order it online.
What about support and service
@Mohammed_Tabrez_Khan the only place that sells it is Prusa’s own site. Gotta order there if you want one.
Name any other which can provide support here in India
@Mohammed_Tabrez_Khan do you specifically want a Prusa MK3
@Mohammed_Tabrez_Khan Prusa is the manufacturer, and provides its own support and service. The Chinese knockoff 3D printer manufacturers generally don’t provide any support or service. Nearly all manufacturers have an online community of their products that provides answers or limited support.
Is prusa the best
At this price point yes
@Mohammed_Tabrez_Khan Since you new to 3d printing, you cannot go wrong with the i3 design. Josef Prusa has made many innovations that everybody else has coppied or ripped off. By purchasing a kit from him you are supporting continued innovations from one of the leaders in home 3d printing. Yes there are other designs such as the Delta, and SLS, but you need to start somewhere, gain knowledge and experience in that design and expand from there.
