Google+ post by D Rob on 2014-04-15 15:02:56 UTC
When is someone going to implement a permanently level bed? One sturdy enough to maintain calibration.
What is the trick here?
apparently the gear motor with worm turns the gear the gear has a component that triggers the 3 releases in its turn one at a time. while that point is released the nozzle pushes it down to 0 with nozzle in place the gear continues around re engaging the lock and then the next 2 points. the lock must be friction based
here is the OP https://groups.google.com/forum/#!topic/makerbot/R3lSfnCz5W4
