Good new!!!WS2815 led had updated and will have trial order next Monday.
fastled-support
gplus
(mandy xie) #1
Someone need to palce trial order pls contact Mandy:sales03@witop-tech.com
WS2815 and CS8812,12V individually addressable led.
WS2815 led is electric capacity inside.
(Yves BAZIN) #2
What are their specificities ?
(Jason Coon) #3
Found the datasheet for WS2815B-V3: http://www.world-semi.com/DownLoadFile/138
Looks like a 12V WS2812/WS2813 variant with capacitor built in.
(Jason Coon) #4
Not finding anything on “CS8812A” LEDs…
(Jeremy Spencer) #5
I’ve just got a strip of GS8208s, 12V version of the WS3813, the strip has capacitors for every led. It works really well with FastLED though :slight_smile:
(Kris J) #6
Newbie question: What’s the cap for? To combat voltage drop along the strip? Or for over voltage protection of the ic ?
(Kris J) #7
@Kris_J I looked at the spec sheet and the Cap is a bypass filter. =)
(Yves BAZIN) #8
If I read correctly the needed current is now 10mA instead of 60mA ? that would be great !!! on top of the failure prevention if on led burns
(Jeremy Spencer) #9
10mA at 12V…
(Jeremy Spencer) #10
I’ve been testng 12V WS2818s and 12V GS8208s… I’ll try and put a post together…
(Marc MERLIN) #11
What’s the cliff notes on it? How is it better than WS 2813?
(Yves BAZIN) #12
@Marc_MERLIN as powered with 12V it requires less current hence less voltage drop for long led strips => less injection points. If I were to make Halloween or Xmas decoration for outside I would go for these instead of the 5V ones
(Marc MERLIN) #13
12V is great, that is a very good move.
(Jeremy Spencer) #14
12V power supplies are also cheaper :slight_smile:
(Jordan Whaley) #15
Will these respond to 5v logic?
(Yves BAZIN) #16
@Jordan_Whaley yes the data signal is 5v logic
(Jeremy Spencer) #17
@Jordan_Whaley , if you’re using a 3.3v MCU you need a level shifter to shift the data to 5v. 3.3v data does not work.
(Jordan Whaley) #18
Very good. Maybe will play with these in the future for larger installations
(mandy xie) #19
@Jordan_Whaley Yes,it is OK to offer u ,maybe you can contact me at sales03@witop-tech.com in the future
(mandy xie) #20
@Jason_Coon CS8812 is WITOP led,it is the updated GS8208.But Built-in IC,and data sheet can be sent,pls contact Mandy:sales03@witop-tech.com
