Good morning,
I have a new k50 and feel like I got it aligned well but my engraving has a bit of ghosting to it. If u look at the S and the C in the name u can see what I’m talking about.
Is there any other reason this could happen? Maybe a setting somewhere in the software for example? Or would misalignment be the only reason?
I’m using the lightburn software with stock controller
Thanks for the troubleshoot …I’m only using scan…and it happens regardless of speed, but the slower the speed the less it shows, but it still shows up…I have the material taped down. Of it’s not the alignment my next guess would be the belt but I’ve tightened the tension screw as well…no help
@Nathan_Thomas Could the vertical laser beam (passing through the lens) bounce/reflect in anyway ? check verticality, cracked mirror/lens. Also a chance to clean them.
SOLVED
just wanted to update this post in case anyone else comes across this issue
It was solved by using the reverse interval scan.
I’m using Lightburn so that is done by going to Edit ---- Device Settings
From there you can set some random intervals until your lines match up on the right hand side. There’s a very detailed write up on how to do this in the LB Facebook group as well
