Good morning all! Smoothie is all wired up for driving around the X,Y axis and testing the endstops… Quick question what Firmware build should I be using? And can someone point me to a config file or share some of the config settings that you are using
I use David Cooks config and pin choices.
Ok… I just looked at the master branch and yes the laser module is active. I was under the impression it was kabashed as well as on edge. Current master it is then.
Thanks for the heads up +Peter van der Walt and @Domenic_Di_Giorgio1
