@cprezzi That did it, you were exactly right. Everything works perfectly now. There is only the slight annoyance of the laser firing at 100% for about a second after connecting the machine in Laserweb, but other than that everything is working beautifully. I really can’t thank you enough for all the help, you save me a lot of time and potentially also some money!
I just have one more quick unrelated question: I got myself new TMC2130 stepper drivers, they’re identical and one works fine, but in whichever axis the other one is plugged in only goes in one direction (negative) while Laserweb reports it working normally. Wondered if you maybe knew why that is, it’s probably an easy fix, if not I’ll dig out the solution on my own, no worries.
