Good afternoon Good People …
i already Maked Cnc Laser With arduino and laser Head 2.5w … i faceing people in engraving photo … some image be good in engraving and some is very bad in finally … and all photo i think they same
why i faceing thia problem
here is exmple … some is good and other is very bad … could some one help me thanks
looks like the power is a bit higher then needed, the moon has burn spots from flare ups. Maybe try air assist to control that? and the last one looks like there is a bit of jitter, maybe going too fast? try lower power and speed and see if that helps.
@Domm434 Thanks for Replay
what u meen with air assist ?! Please … and i faceing this problem in engraving personal photos
air assist as in a stream of air blowing from the laser head onto the work piece, its not standard on K40’s. Easy to add with an aquarium pump and some hose. it helps blow out the flare ups.
@Domm434
It will Help ?! … i Have Module Laser 2.5w . Not laser like K40’s
What u think ?!
It’s used to keep away smoke from laser, increasing efective power and making a constant burn.
@Joan_Sunyol
Ok Thanks … i Still Have Problem with Create Personal Photo to engrave … i Already Make Alot of time But its failure
What’s your hardware? Arduino? Version of “firmware”?
Arduino … Grbl 1.1
@Joan_Sunyol
And what settings you have in grbl?
@Joan_Sunyol
$0=10
$1=25
$2=0
$3=6
$4=0
$5=0
$6=0
$10=0
$11=0.020
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=1
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=160.000
$110=6000.000
$111=6000.000
$112=6000.000
$120=50.000
$121=50.000
$122=1000.000
$130=200.000
$131=200.000
$132=200.000
I have a similar setup, but in speed (110,111,112) I have a more conservative values. Also your accelerations are way more bigger than mines, maybe this affects the way it engraves.
@Joan_Sunyol
U Have One With Arduino Like Me ?
How i can Fix this im New In This Project
Thanks For Replay
@Joan_Sunyol
Any Help Please
Hi, i have an elekmaker a5 laser 2.5W.
Can you post the original file you are trying to engrave, and the configuration on laserweb?
@Joan_Sunyol
Hello This Is My Try Right Now and THis is Original Photo And Configuration in LW
And this is the result very bad trying @Joan_Sunyol
And the result of this settings?
Usually in my setup, I have to set the range from 15-20% white to 100% black.
I prefer to use a photo editor to set it b/w and save before using in LW
Ok, posted before me.
Yes, not the bests results.
@Joan_Sunyol
Can u Tell Me How u Do it Be4 u get it In LW … and What the photo Editor u Using to Help Me … thanks For Helping Me Really
