Going through the BOM, is there any reason it includes the GT2 pulleys from Misumi when there are similar ones on robot dig for a fraction of the price?
You may have trouble with the hubs on the robotdigg pulleys not allowing enough clearance in some cases, as they may interfere between the x and y shafts. You may be able to make them work though. If so, please post pics, and I’ll update the BOM.
Actually, for the 8mm bore pulleys on the bottom of the lead screws, you could probably get away with the robotdigg pulleys without a problem. I didn’t read your original post closely enough, and thought you were asking about the 10mm bore pulleys on the xy shafts. I actually already accounted for the xy shaft clearance issues in the BOM, which is why there are 10mm bore pulleys from both Misumi and Robotdigg.
@Ben_Delarre Yes, there is also clearance for the 5mm pulleys. @Eclsnowman probably has the most updated design (https://github.com/eclsnowman/Lien3D_Eustathios_Spider), but I’m not sure if it includes the most recent pulley updates. Robotdigg didn’t carry all of these pulleys when I created the original belt/pulley based design.
@Jason_Smith yeah I’ve noticed that they have been keeping an eye on all the 3d printer makers out there and seem to be rolling out whats popular. I tried @Eclsnowman’s github but that appears to be a later version, guess its time for an upgrade unless Eric can output them in another format?
@Jason_Smith going through the misumi parts now, looks like they no longer do the 56mm length stepped shaft at the end of the lead screws, they only go up to 40mm. Looking at the 3d model this might actually mean the z-axis motor mount needs changing to raise the motor shaft to keep that pulley aligned?
@Ben_Delarre Ben there should be a folder on the github called other formats. Some formats are a little behind the solidworks version. But there is a step version from 9-11-14.
I have the robotdigg pulleys modeled on my HercuLien. I will make a model configuration of Eustathios with the robotdigg pulleys. They are a much better value.
@Eclsnowman excellent that would be great. I took a look at the models as they stand and it looks like you would only need 2 of the 10mm bore pulleys and the rest could be RobotDigg. Then the hubless ones are used near the bearing holder and the hubbed ones can go next to them without issue. All the other pulleys look to have enough clearance already.
