G2core. Please make the firmware uploader be able to load local files.
Hint: Copy your binary to a cloud drive, you should be able then to paste the URL into the CP firmware downloader
Yes sure, this is not the point of my post… I guess that those like myself who adventure in the g2core compiling will need to do that many times before getting it properly, also considering people working on development. If you fork on github than you can use raw urls but if you just wnat to do some experiments locally then every time you have to copy it for example in dropbox, tweak the url, etc.
If you are going to do development on the code base I’d recommend getting the Atmel-ICE and doing it that way. You get a real-time debugger, too.
