When I home one axis individually, it homes the speed I expect: the speeds set in the configuration file. I have them set to initial travel at a speed of 50mm/s and then 35mm/s for the slow homing speed.
But if I send G28, the X and Y axes move at a very slow speed, probably around 5mm/s. I’m not sure why this would happen. I’ve searched around the config file and can’t find anything that would cause this.
Any ideas?
Imported from wikidot
