Hi there,
I’m trying to replace this fluorescent bulb with its LED equivalent- it has g10q pins, 40cm in diameter. In the picture it’s the fluorescent tube with an electronic ballast. The LED version needs something else to work but I’m not sure what.
I have never used one of these but perhaps I can help…
" Connects to conventional fixtures or mains
This circular LED tube can be connected to a conventional fixture (one that has a starter) or it can be connected directly to the mains."
The ballast in your previous lamp may not be compatible (electronic vs starter). However the specs say this lamp can be connected directly to the mains.
I take this to mean that you can bypass your electronic ballast and wire directly to the lamp??
Thanks donkjr.
So I bought the original fluorescent bulb and then found the electronic ballast separately which I wired up to a power cord/ mains.
I have no lamp base or other fittings.
I bought the LED bulb and thought it might just hook up to the ballast but no joy.
I was hoping there might be a similar ‘kit’ or component I could by to connect to a power cord but haven’t found anything.
Would you have any suggestions?
I am pretty sure you just need to connect the mains directly to the led bulb.
You could do this by cutting the ballast off the g10q socket leaving enough wire to connect the mains. Then connect the mains to the 4 pins on the g10q connector.
The problem is that I do not know which pins are what on that LED bulb.
I would use the # above to call any-lamp and get that info.
Some research suggests that 2 pins of the 4 are neutral and 2 are hot but I do not know what pins.
Cheers donkjr!
I’m a bit embarrassed to say I don’t know how to check the 220v and I guess that’s why I thought there should be an intermediate component to regulate the voltage.
I’m in Europe so if it runs from a domestic or common mains supply is there a way I can check/ regulate the flow? The internet tells me that Europe has harmonised voltage at a range of 207-253v (nominally 230v) but is there something else I should do to ensure safety?
How is this lamp being used and where and how do you plan to plug or wire it in at.
You would need a switch in series with the mains if you want to turn it on/off rather than just pull the plug.
A fused plug would be a good idea if you plan on plugging this into an outlet.
@cprezzi, @StephaneBUISSON or others in europe, do you have practical suggestions for wiring the the above lamp. I do not know what switches plugs and wire that may be available in Europe.
It’s going to be sitting on the floor of a gallery space as part of an arrangement of items. Yes, was intending on using a fused plug directly to an outlet. It’s not necessarily important to have a switch that cuts the power, I guess I just want to ensure there isn’t a power surge or other issue that could cause harm. Thanks!
Anyone know of a place to get a MALE G10q connector with pigtails?
I’m looking to add a smart controller into an older T9 equipped light, and having a male connector would allow me to do it without hacking into the existing wiring.
