Fusion 360 with Dremel 3D40 Help
I am hoping someone can help me with this specific issue I’m having with trying to make a 3d model of a custom pipe. I am not sure if this is a Dremel issue since that is how I’m printing or an issue that I am causing with Fusion 360. When I slice and preview the desired section of pipe that I am trying to print some of the curved sections come out not fully filled but others with the same radius are perfectly fine. Has anyone ran into this issue before and able to assist in some way? This is all being made in Fusion 360, exported to an STL file and sent through Dremel DigiLab for reparing, layout, and printing.
This looks like a wall thickness issue or a bad mesh. You imply it needed repair… that’s never a good sign.
Please upload the original stl, I’m curious to see if it slices properly with (say) prusaslicer. This would narrow down wether the problem is with the output from fusion, or o problem with Dremel’s online tools
