Full full piece on my MM2 using a PrusaNozzle.
Beautiful finish on the piece, would have been perfect except for a X slip you can clearly see.
I’m thinking if upgrading to the Prusa Nozzle did you have to tweak it at all or did it work out of the box? I’d be upgrading from a j-head MKVB
@Jeremy_G_WeisTek_Eng Like any head it needs a littel tweaking. A few M303 PID autotune runs.
It also requires much higher temps than a J-Head i.e running PLA @240C on the Prusa where on a J-Head same PLA runs nice @185-190C.
I suspect that due to steel being somewhat of an insulator compared to brass and steel dissipates heat much much faster than brass.
Overall it’s been a good experience so far.
