Coming from Repetier, I must be missing something. I can setup homing, and it stops at 0. If I run into the endstop after that, it crashes it. It does not stop like homing. I had a situation where I was leveling the bed and was 2mm up on z and decided to move it 10mm thinking it would trigger the endstop. Nope. My z axis got all screwed up and unlevel. So do I need to setup each endstop as a limit switch as well? My understanding is this shuts down the printer. Repetier did not do that. Is there a way around that?
Imported from wikidot
