For the Eustathios, what size bolt are people using for the end stops? It seems like M3 is too large for the E3D end stops I have and the 3D part.
Also, what are people using to bolt the belt tensioner C with tensioners A and B? Misuma USA doesn’t seem to offer an M3 30mm bolt (BCB3-30).
Thanks for your help.
I’ve carefully put a 3mm drill through the E3D end stop holes and used M3 screws. Works fine.
Mini basic switches have holes for 2.5mm screws.
I use zip ties. They work great.
I drill them out to 3mm also. Who the heck keeps 2.5mm bolts around. I have buckets of 3mm.
If you’re in the US you can use #2 screws. Otherwise, M2 will work, if you have them.
I decided to get some M2 16mm bolts from McMaster Carr. Thanks for the advice everyone.
