For Home/Small company which electronics recommends to use with a CNC 30x60cm with 10W
For Home/Small company which electronics recommends to use with a CNC 30x60cm with 10W laser and spindle.? to use with Laser Web!
I would suggest a Grbl 0.9 compatible Eleksmaker board like this: https://de.aliexpress.com/item/X1-DIY-mini-laser-engraver-3-axis-stepper-motor-drive-control-board-GRBL/32697589435.html?spm=a2g0x.search0302.4.103.4vYP60
They are used on most chinese diode laser engravers.
Thanks claudio! this board works with grbl1.1 too? or just with 0.9?
All boards for grbl 0.9 should be compatible with grbl 1.1 because the pin mapping didn’t change since 0.9.
dont come with that board and really sux, will try to get some of these! Thanks… another question… exist some “industrial grade” or “much better components board”?
There are DSP controller boards on most industrial laser cutters, but they need proprietary drivers and dont understand gcode. And they are expensive.
