Hi all,
I have started this hackaday project to design a foam cutter controller.
FluidNC 4 axis foam cutter controller
Of course everything will be open source and open hardware.
PCB is under production at PCBWay and will be available there.
I’ll keep you informed on this page as soon as this project will progress !
current specifications are:
- able to drive a hot wire
- equiped with 4 bipolar steppers
- driven by standard polulu shields
- and with a “heart” ESP32 MCU
- FluidNC driven
- able to “eat” gcode produced by any “foam cutter” software
regarding this last feature I sincerely hope to test it with GRBLGru !
I have taken benefit of 11th/11 and bought the 4x drivers for less than than 4€ and 4x 1.5A NEMA17 bipolar steppers for 22€ (shipment included)
ESP32 costs less than 5€. So it will be a very cheap board
I have just received the PCBs!
They look great !
Hi There,
PCB is soldered and the four steppers motors run perfectly!
I still need to test the hotwire but I am very confident !
Ok so now fully tested ! It works.
So it has become the first “Fluidnc official foam cutter board”
See here : fluidNC existing hardware
bottom of the page
Hi,
I have struggled a lot with GRBLhotwire… Since beginning of december it didin’t work neither with my MM2001 board nor with my new FluidNC foam cutter board.
Bart and Mitch from FluidNC helped me to correct a few non blocking bugs of GRBLhotWire (release V2.9 PR2). But it didn’t correct the major blocking problem.
I also exchanged with RC Keith who is maintaining GRBLHotwire.
He finally discovered that the bug wasn’t in our sides (My board, FluidNC nor GRBLhotwire App) but on Microsoft side after latest upgrade of Windows10 and 11…
The serial driver no longer works properly…
Keith has documented this bug on his web site : driver problem
Reinstalling previous drivers corrects the issue…
On my side I have finished to test my board. It’s working perfectly now
Documentation is deeply updated and contains not only how to do it but also how to use it:
hackaday project
PCBWay board
Finally I have finished a plane using this foam cutter board + Jedicut software + GRBLhotwire
Result is a 2.5m “Zenity” glider built totally from “scratch CAD”. Its weght is 1.2kg ready to fly !
I have finally published all the process to design and build this plane.
It’s here : zenity a 2.5m glider
