Floating regions fix
Hi, I have an object to print and I always printed this object when it had a flat top now I added an angled top but it keeps saying it has floating regions, so what I cant print any angled objects? Does anyone know how to fix this issue on the slicer?
jelly 1.3mf (5.9 MB)
To me, it looks like there is no top at all. The walls are a single plane with no thickness. Did you accidentally remove something?
The clue is in the bottom left of the window Error: non manifold edges, you have chopped the top off the model at an angle OK, but did not repair the model to make it solid again.
I suggest you try the repair option they give there.
You could go back to the CAD program and put a surface back across the angled top and then split it from the rest of the object. Delete what you don’t need to create the solid and then add that surface to the polysurface you have. Then save that as the STL. I wish I had a dollar for every time I had to do the same thing.
