first try at timelaps of #cheapQR printing a vase thingy. unfortunately not water tight. @shauki mind sharing slicer & firmware settings?
& 2nd part:
@shauki it was PET (nGen). the effect occured on every “return” point of the nozzle. it has 2 outline walls. i don’t think it was plattform tilt. anyhow the linear bearings are gone by today
@shauki there you go: Onshape
but be aware that i’m still constantly tinkering without any greater plan. e.g. the z lower idler bearings need to come a bit closer to have perfectly parallel belts.
do you have cad files for the #turtleArc?
