First successful test…
Seems like the cut line is a bit wide?
Yes, it is… Need to finish setting up the details, etc.
Just wanted to know whether it worked!
Its alive Looks like you did not set the focus G28.2Z will tell the bed to home to the head, a good macro to make
also you could probably move a little faster when cutting
Still need to do those things… This was just an initial test to make sure it all works, but haven’t been able to get LW4 to do the min/max tests for X and Y yet either…
Next time, work from inside to outside. First engrave, second small inner cutouts, last outside cutting.
This was just a quick’n’dirty test
