First successful test with 3mm plywood ;-) Did a couple of runs to cut
First successful test with 3mm plywood :wink:
Did a couple of runs to cut through (10x with z 0.1mm) down per run
I have to learn a lot about laser cutting and engraving :wink:
Note the left side frame.
The frame was created by tracing with LW3.
I just wonder why it isn’t closed.
Is a setting that I missed?
I knew I saw the setting somewhere …found it, thanks!
That seems to do the trick - frame is gone :wink:
+Peter van der Walt 3.8W JTech
Did you see my entry here:
https://plus.google.com/communities/115879488566665599508/stream/a2f2443f-7f1d-41e1-9ba6-47a844b25761
This is the correct link …I hope
https://plus.google.com/+PetervanderWalt/posts/WDjFjxiuYai
