These machines are very temperamental. What was wrong with mine was I had the Z switches wired wrong. So I figured that I could just switch them in tinyg programming. which it did kind of work with the exception of jogging down then up to home. When i physically switched the wires everything worked great. I don’t know if it was Tinyg or cncjs or both that this didn’t agree with but it is fixed now.
I guess thank God for these problems or else we wouldn’t learn and be able to help each other. Like everyone here did. Once again thank you.
On a side note does anyone have a dust collector file?
If you are looking for the cyclone section… I built my own. Works pretty efficiently as the pre-separator before a shopvac. I tried to use easy to source components.
I seen numerous different versions on thingiverse. For 3d Printers to print out. I haven’t tried them yet. I just zip-tied my hose to the side of the spindle at this point.
