First, I would like to thank the developers! What an amazing tool.
I have a quick question for John Lauer if you have a moment. I am a wood turner and I am trying to develop a lathe indexer for a wood lathe. To this end, I am trying to add an XYZ widget from GRBL to my workspace. In the part 2 video, you choose “Fork using GITHUB”, but when I try this on the XYZ widget, I don’t get this option, so there isn’t any sample code to copy like you demonstrate. Can you point me in the right direction?
Thanks again,
Justin
Hey there! I’m not John and I don’t play him on TV, but this should be what you are looking for: https://github.com/chilipeppr/widget-axes
Just fork from there to your GitHub account and proceed to Cloud9…
If you check the /chilipeppr list of repositories, you will also find WCS - that one is only in the Ti yG workspace (I don’t know why). I’ll check later if axes widget is unique for grbl and if so will port to github so you have something to work from directly.
@Kevin_Hauser I think I’m quoting you on the tv bit, it’s a great phrase.
Thanks Ray!
Yes, what ray said.
@raykholo ​ could be … But it’s kind of common around this part of the globe.
