First design of my improved, heated conveyor belt.
The left side is just a mirror of the right and thus not included.
Rigth side is broken up into 2 parts to fit the tiny build surface.
  • Belt-tensioning is integrated.
  • low rider should give about 10mm more Z build volume
  • ABP can be removed without any screws to be exchanged for a different build platform (e.g. PCB vice for milling circuit boards)
    I tried to take advantage of the face that I’m not limited to flat laser cutting and use the third dimension to make things stronger.
Next step: printing and trying it of to see what meassurements don’t fit in real life.
Blog:
In the meantime:
makes ABP belt tensioner and removable ABP mod compatible with each other.
It’s 23:00 and I’m printing the first part of this ABP-replacement…
