First attempt at engraving on glass with a diamond drag bit. I thought for sure I would crack the glass but it turned out fairly well. I left the TinyG setup for laser work so the jerk settings probably should be adjusted more for normal operation. Can’t wait to try some other ideas on acrylic.
Very nice!
Super awesome! @Phil_Aldrich do you have a link to where you sourced the diamond drag bit? I really like your tslot table with rockler hold downs
This is super cool. I’ve never seen a drag bit in action. Love it.
Widget works carries the diamond drag bits - warning, not cheap.
http://www.widgetworksunlimited.com
The T slot table is great and I highly recommend it.
Very nice, the diamond tip themself can u get for $25: http://www.widgetworksunlimited.com/Replacement_Tip_for_Diamond_Engraving_Bit_90_p/cnc-dmnd_engrv-rb_90.htmhttp://www.widgetworksunlimited.com/Replacement_Tip_for_Diamond_Engraving_Bit_90_p/cnc-dmnd_engrv-rb_90.htm
