Finished building and Quadrap printer made its first part today. Little robot looks ugly because the printer needs some more configuration but it is working ! Also did a little upgrade to the #extruder feeder to clamp the teflon tube.
So now i can strat to print upgrade parts to transform it to Motedis QR
Once you can even get semi-messy mechanically accurate parts, you become unstoppable in the upgrades you can make
congrats on your first print, doesn’t look too bad, my first print was worse…
Hey Shauki, thanks for all the tips. You mean the Drive Gear ? Its from here http://www.aliexpress.com/item/Free-Shipping-3D-Printer-1-75mm-Filament-MK8-Stainless-Steel-Drive-Gear/32222568980.html . Works good with PLA , but i cant compare because its the only one I have.
